75100 pro V2, UART problem
The propeller starts turning at 15% and reaches its maximum speed at 18%.
ESC : Flipsky 75100 pro V2
Remote : VX3 Pro
UART mode
I tried current control and duty cycle, same problem.
Do you know how to correct it ?
Is the prop in the water or air?
If it’s in the air, it’s normal, works as designed with current control. For bench test you can switch to duty cycle. In the water, most people pefer current control as current is proportional to thrust.
The prop was in the air. Duty cycle.
I will try in water.Thanks
