80100 Duct for Safety
This table values say that between 2000 and 5000 rpm, the Durajet is only 7% (1) less efficient than the tested propeller (in fact 7% more rpm needed to reach the same prop speed). Durajet do not precise which type of propeller it was. Probably not an efficient one to give Durajet a chance.
(1) (7% + 14% + 3% +5%) / 4
@SoEFoil where can I get such propellor?
Unfortunately, not usable as is. As @borntosurf222 said earlier, those potential candidates have to be scaled down for our use and still to be tested :worried:
Hmmm bad I’m getting close to my finished build but this is necessary
Watch my build pls
CNC’d prop. After over 10 printed props I’d had enough, time to upgrade!!
Order… :laughing:
20char 20char
Is it your 156mm prop ?
can you prove the graph is false?
Which diagram? I seem to recal the durajet data was slightly contradictory.
forums are people’s opinions but faking a graph is illegal and could result in fines or a lawsuit.
false advertising, bait and switch, misrepresentation and so on…
the durajet is NOT a jet engine it is more what a ducted fan is to a propeller or a bypass turbo prop for example…I have no desire to argue fyi just to learn :slight_smile:
Yes, with simple logic…
Very few outboard manufacturers bother with Durajet. If it was the best, everyone would recommend them or use them.
Now for simple science…
  • With a prop only, all you have in terms of forward resistance at high speed is the foot of the engine and prop. Therefore way less resistance. In addition you can suit prop pitch to motor powerband.
  • With Durajet you have a giant shroud around a lower pitch impeller. So one, you need more HP to get to the same speed (more petrol used), two , the giant shroud creates way more forward resistance at speed. Therefore higher RPM, more fuel and less efficiency.
    These effects have been shown in all jet drives and even here on this forum when the like of FR takes his shroud off his motors to get his max top speed.
True I have a idea now for a good duct and my build will be finished next week. I will take it one time off for max speed test.
Yeah. Same 156mm prop cnc’d in China. US$150ish plus shipping.
Who is faking what ?
Jezza I see the flaw in your logic. Do you have any formal training in physics, fluid dynamics or engineering?
You need a good understanding of wing tip vortices to understand this.
Fluid dynamics and compressibility, withtou that its like trying to understand quantum physics without calculus.
Jezza is convinced Durajet faked their graph.
He maintains people have proven his theory from and said quote:
If that’s from durajet it’s a load of rubbish. On forums it’s already been proved to be Les efficient. If it was more efficient, every motor company would abandon STD props.
and this:
Jezza
3d
I personally take a graph published by a manufacturer with more rigour than ā€œforumsā€ but that is just me. Granted durajet has a vested interest but lying in print can be extremely expensive…
Lastly, he is missing a key point but I am patenting the IP so I am not at liberty to explain it, nor do I feel it is my responsibiiility…lol
cheers
Piotr
It was also pointed out that important details were missing from these graphs. If you struggle to be 7% slower at the cost of an extra 15% fuel consumption (or AMP drawn) the number of interested customers will necessarily be low if safety is not the goal.
When could we see the proven benefits of this ? Could it be adapted to efoils ?
Yes in all actually…
But you don’t need formal training to to understand the simplicity of it. A prop with no duct has zero added resistance at high speed.
Durajet has a huge amount of added resistance at high speed. The advantages durajet offers would only be at low speeds and in the realms of safety.
If ducts and jet-drives added benefits in the realms of high speed, all powerboats would use them for racing. It’s that simple.
Your fabled graph doesn’t even indicate what pitch propellor they tested with, which is a huge factor to consider.
If you want to attempt to prove me wrong, build or buy a durajet.
Ah so I managed to find the dimensions of the prop that was used for the graph!
Durajet deliberately under-propped the the engine. They used a 13.5" x 11 pitch prop.
That motor normally uses a prop with a pitch somewhere between 13 - 19. That will make a HUGE difference in the stats!
In Canada we cannot have a propeller. So the proven benefit is you are not risking a huge fine, never mind missing fingers and toes.
Jezza has replied as well so I will address my point in that reply since he is bringing up more esoteric information.
