Hi Guys, I hit a big fish and it got stuck in my Lift propeller this afternoon, I had to swim to shore to remove it…
After removing the fish the propeller wouldn’t move and I would hear some light “beep” noise coming from the board when pressing the controller, after 30 minutes the propeller started turning again but it made a lot of noise with half its normal power. It is as if the shaft is not fully engaged anymore. I can’t see any physical damages on the propeller and the main propeller screw is very tightly screwed.
Have you come across this is issue before? Any suggestion how to fix it?
Many Thanks!!
