I am using the Manta prop for my Flipsky 65161 motor tow boogie build. Is there a good source for stainless steel prop pins? I haven’t had any luck searching online.
Thanks much for your help!
I use these (after cutting them in half):
Uxcell a15091700ux0090 304 Stainless Steel Dowel Pins Fastener Elements 3mmx40mm Stainless Steel (Pack of 10) https://www.amazon.com/dp/B01DZZUPEC/ref=cm_sw_r_apan_glt_fabc_ZSG7JXDNBV9GB8C7T75F?_encoding=UTF8&psc=1
Our hardware store has 5/32 (3.97mm) brass rod. Just cut to length.
I picked up a 3mm prop shear pin from a local boating shop.
cut a stainless steel nail (< $0.05).
You can buy them also from aliexpress, but the price is out of this world…
Awesome! Thanks so much!
