In efoil mode, how long does it take to drain in 8s3p, 12s2p, other config you’ve tried ? As an indication, how much do you weigh ?
This looks exactly like what i need to do with my setup. I have the exact same ESC and box. Couple of questions:
How did you mount the ESC on the inside to the heatsink. just adhesive paste or did you bolt somehow? Did you remove the Flycolor alu cover on the outside to expose the mosfets and just mount hard against the heatsink? Cheers
I can ride my 12S2P molicel p45b 25 minutes and I cruise at 65% on 5.5 km.
I left everything as it is on the ESC, glued the heatsink on an alu plate which replace the plastic wall of the box and stuck an outside heatsink on it. Very nice to use on 12S2P, 40amp current limit, not a lot of heat.
