Hallo
I am new here and in the electric Foil or Surf World.
I am from Schwitzerland and go as muck as i can Kiting. Tipend on the conditions on wather, land or snow.
Sins i ride my Levitaz Cruizer with the Match Board and the 80cm Mast.
I came realy in love with Hydrofoiling. (no more ubwind strugeling haha)
And i also build a pretty strong e-Mountainboard i also wantet to build me an e-Foil, but! with an Levitaz Foil.
I am a profesional welder… i just love it
I am trying to do a Foilboard out of aluminium and foam…
I made a prototyp out of 2mm (bether for modeling).
So i had the form… Now i am plaining to do the same in 1mm Alu.sheets.
9kg is quit heavy for a board hahaha.
So now i hope you have intresse in this projekt and want to help me.
As you see, i thing spending one or twoo hundred mor and have e bether produkt is bether than buy a cheap one and buy two times
Trampa, Levitaz APS, Flysurfer… they build good stuf.
My thought is to take a Levitaz Hybrid Mast and take the Carbon or Phiberglas away
And Weld an Aluminium Mast Profile between the twoo Alu segments from Levitaz.
after i welded this and grinded the welds i want to make the motormount one or twoo cm from the Fuselage, and use a jet prob, so i have no drag for slow gliding.
or may with a folding prop like from sailing boats?
But i realy do not know wich motor i have to use or what prop or jet…
I just know i want to use the vesc, because i am familare with the program.
Why not the Vesc 75/300
I know it is not the easiest Foil to Build an e.Foil and without Carbon-epoxy strukture…
But i realy want to use Levitaz because i also Kite with this brand.
And you can swich the Wings so easy!
hahaha Chose between Shaka L and Bionic or aspect…
I hobe we can discuss here and come to a good Component list.
LG Pascal Kuster
Ps: Dam i am a new user and can only post one picture… sorry
