I would like to know where non-US builders here got their aluminum tubing from and what diameters you used. Outside the US it is hard to find tubings with imperial measurements (without paying high shipping costs from US), I only can get my hands on metric tubings with 57mm ID, so the motor would tightly fit (if I am lucky), the imperial ones have the advantage of being just slightly bigger.
edit: I just realized that the motor indeed is 56mm in diameter (hence the name), so 60mm OD, 57ID will fit well.
Hi Benjo,
i bought the Tube suggested by Pacific Meister on is material list and ordered from e-bay. Exterior is 60mm and interior is almost 57mm. I measure 56,5mm . Engine fits nice inside.
Thank you for your answers, interesting that the motor fits in 56.5 and even 56mm, it is probably not exactly 57mm then (of course all measurements aren’t exact).
I found the exact tubing from pacificmeister’s BOM for 39.49€ from a different seller on amazon and for 31.70€ on ebay, both incl. shipping to Germany.
And I would pay 10.21€ for a metrical tubing with 60mm OD and 57mm ID from Germany, so I’ll probably try that one as the motor seems to fit in 56mm as well.
Thanks!
Just measured my motor… it’s 56mm… i remember long time ago pacificmeister add some problems with a tube too tight… I guess it all depends on the manufacturing process. There are some small variations in the diameter. In 57mm it will fit for sure.
Hi Benjo,
are you from Germany? I am also from Germany and just ordered an aluminium tube 10 minutes ago here:
It’s 60mm diameter and 2mm thick. I already have the SSS motor here and measured 56mm, so it should work. I can let you know if it fits when the tube is delivered.
P.S.: And it’s only 18€ incl. shipping for 1m length.
yes, I am from Germany. It would be nice to hear if it fits.
I would have ordered here: https://www.alu-verkauf.de/ALUMINIUM/RUNDROHR-PROFILE
Because they also have 1.5mm wall thickness. But I will wait for my motor and measure it first, maybe some motors are 56mm and some 57, no one knows
Unfortunately I live in the very north: Kiel. I will foil in the Baltic Sea.
But maybe one day we could set up a Germany-wide eFoil meeting, maybe also with our Dutch friends
Hi, I`ve tested the 60/2mm and the diameter inside was not big enough.
So I switched to the 60/1,5mm and a plate of aluminium with 0,3mm wound once round the motor.
I got my tube now last week. I am able to insert the motor, but it is very tight. Currently I can only insert it on one side, becaus the other side is a bit smaller because of cutting (Grat). I could try and rasp it a bit, but am not sure if I just buy the thinner one. Did you already get yours?
Hey walther,
I actually “last minute” switched to a direct drive design, so I don’t need it anymore. I thought it would be worth a try.
If you can make it fit it would have a good heat conductivity.
I made a small tool for sanding the inside of 60x2mm tube to fit. Its very simple but works as a charm. Tell me if you would like the 3D CAD for printing.
You would need two small springs (like those that could be found inside ballpoint pens) two M3 screws with nut and of course some sanding paper. I used 150 grit for this.
