Ammo Box 6384 Winch Build
Adding some info here from private message about winch power because I just got a similar question:
Hi, I have a question about your Winch. Are you happy with it and does the motor have enough power? I have a 25l board with foil and weigh 85kg with neo. Thanks already
I’m happy with the winch, but I think for my purposes I should have done a tow boogie instead using an inflatable SUP. It would just result in longer runs, and more general fun out at sea. That said, depending on your area a winch might be the right choice and I’m pretty sure it will work for you. It’s also great for some general surf towing fun for kids and our girlfriends that are significantly smaller than us.
Latest data:
  1. We weight 80-95 KGs.
  2. We can foil a 51L Skywalker board (smallest we have), with a 1500cm Takuma Kujira Helium foil at 13-14km/h with duty set to 50% with a 12s pack (would be 100% if using a 6s)
  3. We can drag ourselves (just our bodies) through the water at a few km/h.
  4. The batteries we have last quite some time. I estimated around 5km of towing on a 12s 5ah based on our last session, but this may vary depending on what percent of the time you are on foil (we suck and spend a lot of time displacing water while trying to stand up).
Question:
Do you plan on starting on your knees on the board with the board submerged, or more of a wakeboard style start? If the former, I think it will be fine. If the latter, I’m not sure how well it will work pulling you over the top of your board. I can test with a kiteboard if it is possible with our current setup next time we are out.
Suggestions:
  1. Depending on the top speed you want to achieve, I would recommend changing the gearing for more torque. In our situation, we could have doubled it. I’m considering dropping our small sprocket from 13 to 10 adding about 30% more torque and reducing top speed (which we don’t come close to anyway) by a proportional amount for a better non-foiling surf fun. This is because for heavy riders on regular surfboards our limiting factor is the motor current (torque) rather than RPM.
  2. I don’t know how long it takes you to get up on such a small board, but consider that given the winch line has a finite length. Unless, you have something like our setup, where if you are good, you can slingshot yourself into some waves heading away from the winch and circle indefinitely.
Happy foiling!
Thank you for your detailed answer. I always start on my knees. What kind of motor current do you have for the 6384 and how warm does the 75100 get? i’m thinking about using the 75200. but as i’m now using two motors, it will be even more expensive.
The 6384 is a Flipsky 140kv.
Neither the motor nor VESC have any heat issues, and I live in a hot climate. Even a touch test right after a few pulls was only mildly warm. This is probably because they are being used less than 50% of the time. After each run, you need to return to your start point allowing everything a rest. So, the 75100 should be just fine. Mine is also a Flipsky.
May I ask why you are going to use two motors? Are you building a super double motor winch like the rewinch, or making two winches? One 6384 motor is plenty for foiling. You can refer to the rough math on pulling power I have in my first post which seems to hold up. Also, at full torque, one 6384 motor is enough to start temporarily deforming my ammo box when the lid isn’t closed. I saw it in videos I was making when trying to figure out why my chain falls. If you are going for two motors in one winch, then I would make sure your construction is super sturdy.
i actually wanted to build a winch with 2 motors, because i bought you in such a way that the power is quite tight. but now i will try it with one motor first. I wanted to use a belt drive now. If the forces become too high, I would switch to roller chains. how much did you pay for your chain drive and where can you get one cheaply?
I live out in Asia so parts are hard to come buy and I generally see what’s available online. The 25H chain sprockets were all I could find that fit my motor shaft, and after some googling I determined the strength of the chain was sufficient. The cost was about 25 USD for the chain and the two sprockets here. Check out “25H sprockets” on Amazon to get a sense of what’s available to ship to you and prices if you don’t have a local online store alternative. I would have preferred belt drive, but I could only find belts aimed for e-skateboards which seemed too weak based on some esk8 forum research. Also, related to this, I could not find any sprockets that worked with the motor keyway, but a dog point set screw has been working well.
Hi there, @foilinghopeful ! What an awesome project. I want to build something similar and have a bunch of questions… would you be down to have a quick phone call? I’m new to this forum so not sure if there is a DM function… let me know! :slight_smile:
Hi, Just let me know the questions on here. It will help others as well, and prevent more of a minor inconvenience I just had with copy/pasting info from DMs back into the public forum to answer the same question covered privately.
Hi, first of all: Thanks a lot for sharing this build with us. It is very inspiring.
I built a simple which for foiling with a cordless drill. It works, but only for light foilers, not for me.
Now I would like to rebuild your winch, but I have a couple of questions e.g.
How did you mount the sprocket on the motor? Did you use a round or a D-shaft? Short or long version? or
How did you install the spool? In particular, how did you attach the sprocket on the spool and how did you install the spool in the box? I noticed that you used bearings. So I assume you used rather a shaft than a hub (I am not sure whether I use the correct English terms). However, it would be great if you could let us know your solution.
Finally: How do you control the speed when foiling? Is there any other throttle than the remote?
Best, Sebas
Hi Sebas,
The sprocket is mounted to the motor using a dog point set screw. The motor I got uses a key/keyway, but I could not find a sprocket that would work with the key. The dog point of the set screw fits nicely into the keyway, and although it doesn’t seem as strong as a key it has been holding up well.
The sprocket is attached to the spool (two aluminum discs) using long m6 bolts with nuts in between the closer aluminum disc and the sprocket as spacers. The spool itself is then just some more long m6 bolts run between the two aluminum discs further from the center covered by some perfectly sized little aluminum tubes to prevent abrasion on the rope from the bolt thread.
And yes, there is a shaft. It is actually attached to the aluminum discs on the inside. The central hole of the large sprocket was much larger than the shaft. Some careful measurement here was required to prevent too much of an uneven spin.
As for foiling speed, it is just the remote. The rider holds it. We reduced the max speed of the winch to about half in the VESC software. So, something to keep in mind here. Choose your gear sizes carefully. I could have gone for more power and less speed perhaps allowing a deep water start or more exciting non-foil pulls.
I hope that helps. Let me know if you have any other questions. Also, here is a picture of the spool without the rope.
Regarding the heat issue, there is a Flipsky video on YouTube with the following summary at the end:
HEAT DISSIPATION TEST of 75100 Series Products
Accordings to this, it should not be a problem to use the 75100 for foiling as the runs won’t last 1:20 min.
Right. We have had no heat issue. Runs are short, and the current draw is only high for a moment before takeoff. Once on foil, little power is used.
First of all, thank you again for this incredibly helpful thread.
I built my Foil Box based on the Ammo Box, and I’d like to share my version of it here. The basic components are essentially the same . I only changed the gear ratio, which I set to 1:8 (10:80 teeth). I also added a Bluetooth module. The box is built on the basis of my previous box.
The key components are:
• 40x40 aluminium profile
• 15 mm screen printing plate
• Flipsky motor 6384 140 KV
• Flipsky VESC 75100 water cooled (I will also use the VESC for e-foiling)
• Flipsky Bluetooth module
• Flipsky VX3 remote with an additional 1.5 m antenna
• 12S 8000 mah Lipo battery (2x 6s in series
• Spool diameter about 140 mm
• Gear ratio 1:8 (10:80 sprocket teeth)
• 3 mm polyproylen seil
• Riders weight: 80-95 kg
• 130 l board
I also built the spool myself. The hardest part was finding the center of the side walls and getting everything aligned. Next time, I’d use a 3D printer to make a drilling template and a centering guide for the sprocket, or just print the whole spool.
The first test run was a success. The setup worked perfectly. Neither the torque nor the speed was an issue. We controlled the speed via the Max RPM setting using Bluetooth and the VESC app. There was still plenty of reserve for a higher speed.
However, the cable inlet needs to be adjusted. It’s currently in the middle of the spool. I’ll move it up to reduce the leverage forces on the spool and cable friction. Additionally, the spool itself needs to be moved further back.
Furthermore, a few settings in the VESC app need to be adjusted (ramping time, settings on the remote control). I’ll likely cover the details of this in a separate thread.
Conclusion:
The setup is great and works excellently. I would build the box this way again, but with 30 x 30 mm aluminum profiles and 9 mm screen printing plates.
That is a very good looking build. A couple of questions if you don’t mind;
  1. what material did you use to make the reel walls?
  2. where did you buy sprockets?
  1. In my case, it was round aluminum plates. I’m pretty sure Sebas used the same.
  2. I live in Asia, and used a local online platform. But, they should be available everywhere. The chain was 25H, which is relatively common. As a result, I imagine you should be able to pick up sprockets for it anywhere.
