Motor: SSS56104 500KV + 5: 1 Parker Battery: Lithium-ion 14S 14P 51.8v 40A
Test result of current value ESC connection from battery
The test showed that the current delivered to the motor side was very high. Therefore, there are many problems such as motor life and AWG life.
Let’s discuss this part.
Motoramps = Torque, so if you want lower motor amps try a smaller propeller or lower pitch.
My tp motor 4070 with 10awg survived the all season with this king of amp …amp goes down when you start to fly properly Full throttle , smaller diameter or area blades lower pitch, smaller wing , loosing weight …
Now the propeller is a 140-pitch 6-inch diameter propeller.
Is there a recommended propeller?
