Are there any live files out there for GongV2 fuse, wings and motormount adapter. There was a folder in search but link seems dead:(
Did you manage to find it? I am looking for a Gong V2 prop guard with the fuselage attachment
for what motor? usually the guard is mainly fixed to the motor with an optional thin bridge to the fuselage …
For Flipsky 65161 (sorry for not mentioning), Flipksy made a 30 degrees change to their screws positions and old files don’t work anymore and I lack the 3D skills to modify an old propguard
I have only managed to find a file that allows the back of engine to be attached to the Gong V2 fuselage but it doesn’t come with a propguard
do you have an STL of an old one with wrong screw positions?
I have added the Old propoguard file and the a tail support with the correct screw alignment here
not a 3d pro either, but comparing the two looks rather like a 20° or 40° change.
I have loaded the guard into Tinkercad, cut the center, rotated it and joined it to the original, maybe this helps?
Looks about right, I’ll start printing and let you know. Thank you
