Another foil assist build from Germany
First I would like to thank all the great people on this forum whose story’s I’ve been following for a long time now. I was always close to start my own project. Anyway I stopped my plans a few times being convinced it makes no sense here in South Germany (black forest) with all the restrictions.
A little bit about myself:
I got into kiting 2016 - kitesurfing became The Thing for two weeks a year on holiday at north sea mostly. All efforts to kite at home ended in disappointment :sweat_smile:
I think 2022 I started with pump foiling on the nearest lake which really became the thing closest to “real” surfing locally.
Last year I learned wing foiling which is also quite nice. Sadly also not the dream conditions here at home.
After getting good enough with the pumping I started imagining catching the waves at north sea must be really fun. So I got finally caught by the foil assist idea and quickly ordered some essentials:
  • Chinese 6384 Motor is already disassembled and waiting for some resin at work
  • Maytech remote for the start
  • X-Cross ESC successfully disassembled
  • CN-Linko connector mt60 (thanks @rttn)
  • planning for a 12s2p pack based on Molicel P45
I have an appletree surf foil board 47l available I would like to use. With 76kg there should be no big issue getting started.
Regarding the enclosure I’m not sure yet. I started playing a little in CAD. Also I have ordered a Bopla A124 Box. To sum it up I have the following options:
  1. FD gen 2 inspired like @Bzhwindtalker. Advantage would be direct cooling by the mast base and not damaging my board. Biggest disadvantage I see is the remote connection and a neat, waterproof battery connection. I would definitely opt for a SLS printed/ milled housing once my design is good.
  2. Inset Bopla aluminium box from the top like @hangloose. But I’m not sure how good signal strength would be. I guess I’d need to make a plastic antenna stripe in the aluminium case - right? Also there would be the need to make room for the cable and connector coming from the motor. I’m not sure how to make the place for the box solid and looking good in an existing board?
  3. Generic FD gen 1 inspired deck mounted box. Could be either Camden or Bopla and also some temporary solution to validate the solution 2.
Happy for any recommendations I’ve not read yet or overlooked. Also happy to meet people nearby maybe for some pumping session in the 78**** region.
Cheers Joshi
The antenna signal with the Bopla is no problem! I have no problems with my 2nd build where I installed the Bopla from below with Maytech V3 Remote. However, my RideEngine board is made of GFK. Since you want to install the Bopla from above, I don’t see any problems with the signal at all.
Good luck with your build! Foiling is what reconnected me to watersports, living 3 hours from the nearest sea.
Regarding the under board, having an antenna extension or longer antenna completely eliminate the signal issue. Handling the antenna is kind of a hassle, but with some adhesive Velcro should solve this.
Being able to change board is great, to go for different disciplines or use case with the same hardware.
A little update on my project:
First of all, thank you so much @hangloose for sharing some more details aside from this thread!
@Bzhwindtalker I see the advantages of having a board-independent system. Also I played around in CAD with my own design of a waterproof under-mast battery. @Jordi is also doing a great job of the FD replica - by the way thank you for the help with my ESC (more on that in a second)
Anyway I think I will continue with the inset Bopla/ aluminium box approach. My main reason is having less seals to worry and minimum drag. Also a 12s3p battery which I want to use would be pretty thick (~70x75x280mm). Remote signal will be improved with some window design or an external antenna.
Let’s talk a little about my progress:
  1. Motor half way prepared. It will get a 2k black top coat which I will also use to seal the stator stack (not potting).
  2. Molded a seal for the phase wires and Cnlinko LP20/ mt60
  3. Working on fixing my ESC. I found a little component missing after disassembly. Luckily @Jordi already helped me to find out what I’m searching for. Maybe someone else could confirm I’m missing a 1608 metric resistor code “60E” which translates to 4,12MOhm.
  4. Enclosure. I already got a Bopla A124 (120x360x81mm). BUT I’d like to get it a little smaller and if possibly lighter. The length and width of the Bopla interferes with my strap plugs which I would like to keep. So I came up with my own design:
    Outside dimensions are 110x315x81mm which saves 45mm in length and makes the Box fit right in between the strap plugs. A nice benefit is the weight saving of about 800g which already accounts for 12 of the 21700 cells.
    To seal the Box I would use the same idea as Bopla probably with silicone:
    Seal
    Pricing would be around 260€ - not cheap but at least cheaper than my prop :slight_smile:
Some off-topic might be interesting for pump-foilers. Im currently also redoing my pump board. It held up great for about 20-25 sessions of pumping. Just bare paulownia laminated to a hollowed core sealed with bionol boat varnish. 30mm thick in total - consisting of 2x5mm (perpendicular fibre) deck, 10mm core hollowed, 2x 5mm bottom (perpendicular fibre). Since I started using the Indiana Condor XL the forces became a little to high leaving dents on the bottom and slowly ripping the printed cones trough the deck. So now it will get a layer of glas to improve surface strength.
Hoping to get a lot done next week.
interested to know more about your pump board, where did you get the wood?
I was looking into airex for my next build, but it’s quite expensive and wood could look very nice for a GF only finish.
Alright I’m happy to help.
Sorry one error, the core is 15mm thick.
Paulownia I ordered in April '24 from ipaulownia
It was 140€ (220€ incl. shipping to Germany) for 20pcs 1000x150x5mm and 10pcs 1000x100x15mm which is enough to do two boards. Boards came planed - I only went over the edges before gluing them wit PU expanding wood glue.
Rocker is done by a simple 3D-printed wedge on a thick multiplex board, some beams an clamps for lamination - also using PU glue.
Some more pictures:
If you like there is also a entire fusion project for the templates and wedge:
Thingiverse
requested a quote, happy to try this for my next pump board build :slight_smile:
Edit : Wedge goes to the edge?
What lamination did you plan for the next version?
Here you can see my “wedge” I use for giving the board its rocker:
Currently I will only repair my first board since the wood is still great. It weights around 2,3kg without glass. at 35mm thickness overall strength is awesome I do not feel any flex when pumping. I cannot noticeably bend the rocker when standing on it with two people, one on each end, 200kg in total.
Since the “no dirty glass/ carbon” strategy did not work out I would probably reduce to 5mm deck/ bottom on 15mm core hollowed with one light layer of glass. The additional 5mm wood top and bottom on my current only where used to get in some cross fibers since planning without fiber glass reinforcement. Mounting points always glass ball filled through-holes - no track needed on a 84cm board.
Another big update on my build here.
  1. Motor is done. I soaked the windings with some special clear insulating varnish made for coils. After drying I gave the rotor and stator a nice coat of 2k black in order to look nice and have some protection from abrasion. Also since I spent some money on the coating and varnish I got a second motor prepared right away.
  2. Motor mount is done. First some prototypes printed in PLA and now I just received a nylon SLS version from JLC. The green spacer is cast from silicone.
Also I started with an 8mm spacer under the mast base. This should accommodate for the phase wires and bullet connectors.
  1. Battery is done. I used some 3D-printed (also nylon from JLC) spacers and end caps. The battery should be semi-waterproof - at least thats my future plan maybe with some new end caps and better shrink wrap. For that reason I use a waterproof connector on the balancing side.
    Some TPU spacers are used to keep the battery in place and thin EVA like foam on the top and bottom.
  2. As you can see the Bopla A124 box is also done. I ground down the markings on the bottom side (around 1mm high) and painted top ant bottom both in black to better fit my carbon board. While doing the cutout on my board I noticed the M20 connector is really long and I’d have to do a cutout under the mast base. For that reason I changed to @hangloose solution of the cable gland. To get a good signal I already ordered some external Bluetooth antenna which will go through the deck and get clued to the box externally.
This was my first configuration which I already tested in our icy rain barrel bath - seems to have a lot of power.
  1. Board destruction phase started with making a big hole in the bottom. Of course taking a lot of safety precautions with the carbon dust (class H Vacuum, Mask etc.) First I cut the carbon layer with the rotary tool and afterwards removed the foam with router and hand tools. It seems that the box will protrude around 5mm from the hull.
  2. Cost until now for the whole setup excluding the foil equipment (mast, base,…) and board I’m at roughly 1200€ with some extra money spent in replacement motor, connectors and other supplies. One should keep in mind I also had to buy the expensive Junsi charger and some tools. So it can be cheaper if you use parts already available and stay with FDM prints.
    Maybe some interesting part prices:
  • JLCCNC Aluminum ESC cooling block: 32€ for two sets (used some coupon codes)
  • JLC3DP Nylon SLS battery spacer: 35€ for one set (also coupon codes)
  • JLC3DP Nylon SLS motor mount: 60€ for on set
  • Wasted around 130€ in wires, connectors I opted not to use and BEC (will be replaced by BEC pro)
Really nice.
Clean and perfectly constructed.
Good work. :call_me_hand:
My resistor marked with 30B, which translates to 2k. Size is approximately 0805.
Maybe it is 80E, which means 6.65M, but I am in doubt.
Ok, I measured - 1.74k. So it is 2k indeed.
Thanks for measuring. I was pretty sure it should be 1608 size by caliper measurement from @Jordi.
Regarding the value your measurement seems to fit the 30B code nicely. I will search for some fitting component tomorrow. Looks like I have to get the controller back out of the box to resolder :confused: it was glued so nicely.
Anyway thanks again!
@lishine thank you for raising that point again.
I just replaced the resistor with a 1608 2kOhm. Worked fine and the size seems to fit well in comparison with your picture.
It seems the change improved a problem I was observing with the throttle response. Before the motor accelerated to full speed fine but holding the remote down it reduced the speed after a moment. I thought it had something to do with a protection feature when not under load (in the air). Now this issue is fixed.
By the way I also measured 1,7k once it was installed.
Great :smiley:
Build is done - I’m just waiting for the nearest lake to unfreeze for the initial test session.
  1. Thanks to @hangloose and his vacuum pump the carbon box became a success in the second attempt. First try went completely wrong - the vacuum cleaner was not enough to keep a good vacuum and got hot, also I learned that it really needs a lot of spare foil and tape to follow the deep box contour.
I’m really happy with the result, only some minor holes in the bottom edge:
After a little sanding, filling of the holes and a thin epoxy coat it looks alright - no filler to save some weight - most of the carbon is covered by the Bopla box anyway
  1. I changed the BEC for pro version and made a little mounting plate. This plate also fixes the antenna in a known spot to make it easier to match the external antenna. The antenna extension is made just from a antenna cable and potted in some printed parts.
  2. One small addition I really enjoy - I configured a WIHA stubby with all the Bits needed for my assist system.
That’s it for the moment:
Very brave cutting up your lovely appletree board.
I hope it works a dream when the lakes thaw out! Looks great and likely inspiration for me to do a v2 after my v1 FD assist style lunchbox on board.
Initial testing went okay today. I used around half a battery lying on the board. Due to connection issues I had to hold the remote directly on the box. So standing up was not easy. I will try to improve my antenna extension for the next session.
Anyway the power is good and no issues with overheating - with the water still freezing cold it would be hard to overheat anyway I guess.
https://www.instagram.com/p/DG8DnuaMf5f/?igsh=OG4zMzBobWx1NDRp
wow nice work… really fine
coud I ask you if the battery it’s build by your self and the size?
12s? 20mah?
Battery is a 12s3p setup with Molicel p45b and self build of course. So it has a total of 13,5Ah.
Had a really fun session lately. About 1 to 1,5 hours on my lake learning how to get on the board and even doing some transitions to pumping :smiley: Mostly on the Indiana 1200 H-AR with condor XS stab.
While I can’t wait for the first chance to hit some waves the development ist ongoing :nerd_face:
The idea is a submerged jet drive - mostly for safety reasons. I started with an SSS5684 800KV. Stripped it to a bare stator and rotor. Then replaced the shaft by a longer one. Designed my own waterproof housing which was done by JLC. Based on some pictures and basic calculations I designed a 60mm turbine. Printed also by JLC in Nylon. First test in the rain barrel gives me hope that the system works.
The most critical point is the shaft seal. In dry run it quickly heats up the shaft just from friction. So maybe switch to a ceramic shaft seal in the next iteration.
For now the next step is to get on the water and check if I can get on foil.
As an engineer I would love to see a comparison between the jet and FD prop. A basic test bench with load cell and power meter is probably what I want to do for the next winter project. This should help to do some improvements in my jet design.
Wow, that’s a very nice looking jet drive! I hope the nylon impeller can hold up to the power and load requirement. I imagine it has thicker blades so it maybe it can.
I believe I’ve read here somewhere that the jet drives are mostly less efficient, at least when compared to a well matched motor and propeller. I think it’s mostly anecdotal evidence and not tests though.
