What’s your thoughts and success so far with maytech foil assist kit at 350$ it’s quite attractive. Is it powerful enough? It’s supposedly nearly same components as foil drive. Wanted to build one and the plans they give seem so simple plug n play, of course vesc tool to set parameters and for iPad user I would need their Bluetooth to connect I’d imagine.
Any one getting up on foil and is this maytech foil assist kit legit?
Conceptually its great. The execution is crap! For some unknown reason Maytech used a stator length of 50mm instead of 56mm. This results in just not enough torque in comparison to Foildrive kit which uses a 56mm stator. The Maytech also is not waterproofed nearly well enough for salt water use.
I did a quick and dirty with a 6384 size motor and the difference in torque was apparent immediately. With a 6384 I can efoil easily. In fact my entire setup is around 11kg and is way more fun than my main efoils…
Ok so what ya suggest? just buying different motor more powerful, and water proof the electronics like FD does. I have the kit sitting with a friend, and now I know why it don’t work as well, what about vesc tool parameters to get the most juice out it? You find the best settings?
Get a Saite 6384 140Kv. They can do all waterproofing and it comes with ceramic bearings. You can contact them via email or through Alibaba or Aliexpress.
If you wanted to swap out just a motor, you’d need to make sure the motors were a near exact match. Foildrive use a saite 6374 but I’m not sure of the exact kv.
If you wanted to build a full new kit then you can go the 6384 route and have a little bit more torque and power if you need it. Then it’s just choosing which ESC you want.
I see. Sounds about right. They just put these kits out there with out any testing. Gets to hot, that’s a big wing so it makes sense ya got on foil even under powered.
