Im almost at the stage where i need to drill my Gong mast.
Any tips greatly appreciated. Whats the best practice? any special ways to seal or protect the cables from rubbing what i assume to be a fairly sharp surface?
Thanks in advance
Thanks in advance
I used a milling machine which made it easy. I then used a rotary tool to round all the edges so that the cables would not get cut. After that I used nail polish to coat the untreated aluminium so that it would not corrode.
is there a perfect distance - foil - motor? or is it as low as possible without fouling?
I not sure. I leave approx 2cm between duct and fuselage/stab.
I also left a little gap of 1.5 - 2cm that would allow for a bigger prop. If you have no duct, a small gap to allow some flex of the motor/fuselage to avoid the prop to hit the fuselage/rear wing might be a good idea.
In general: as low as possible to keep the prop under water.
