Based in the UK (Plymouth) toying with the idea of converting my existing kitesurf foil to electric. (Slingshot hover glide mast and foild and liquid force kitefish board).
Just interested to know if there is anyone else building their own DIY electric Hydrofoil in the UK.
I live right next to a tidal lake which would be the perfect testing ground!
I am using a Temevanto board. I am quite close to finishing it. Just some electronic fitment and minor glassing on the board and it will be water ready. I’d say a days dedicated work would get me there. Therefore it will most likely be done in a months time
I did all the 3D printing and milling (by hand) myself. The board is the one that used to come with the Taora sword foil: https://i.ebayimg.com/00/s/MTAyNFg3Njg=/z/h~YAAOSwdHBaY4-d/$_86.JPG (that’s the exact board I bought).
I’m an engineer so from a technical standpoint I don’t think the project is too intense. I’m trying to keep everything as simple and cheap as possible. I am very keen to see the results of the 45mm pod build on the forum as I think it could be good cheap option.
I also have a 100KV 4KW outrunner that I plan to use as a direct drive unit, but who knows when I’ll even get round to that.
Mine is up and running successfully! Did a test today and it worked great. I just need better batteries to really see how it handles over a longer period of time!
Haven’t started yet as been pretty busy with work and have a young baby however I am still keen as I live right next to a tidal lake which would be perfect. Actually sent you a PM on facebook last night in response to your question about Chinese foils.
Jezza - congratulations on your build, glad you are up and riding.
I am based in newport South Wales and have built an efoil and tested okay… its a cross between Pacific meister and Hoirthys builds. Got water issues so looking to do a rev 2 build soon
I want to go down the 18650 route from the outset if I can, but I’m a bit lost with the whole electrical / BMS requirement to be honest. I want to use the same motor, gearbox and prop as @Silvio to keep the overall diameter down.
I’m based in Warsash in Southampton and am starting a project for my 2nd year product design task. Money is the only problem for me as I windsurf so have 3 boards etc but can’t afford to buy another ESC if I melt it by accident or buy the wrong motor
The ESC is not nearly good enough. I would not go under a 120A ESC and I would pick one that can be watercooled. If you go cheap, you will need to mod the heatsinks so that it can handle the constant current. The seaking 130V HV is well proven on this forum.
Those batteries are too small. You will only get about 4-5 minutes of fun, and they also wont handle the current draw from the motor. I have tested with similar and they are just too weak.
I you want the batteries to last, go for something that can supply around 200A constant current. I’d also get a capacity of at least 10000mah so that you have around 10min of play time. Less than that is a mission.
I haven’t heard great things about that ESC. I would definitely favour the Seaking 130A HV over it.
