Assist V.2 Green board
I started my motorized life this may with a simple conversion of my SUP-foil board. Worked well enough, but next step was something less bulky.
So I did my second iteration with a simple XPS board and standard components.
Board is 41l , 5’4 by 19" with a hatch for the electronics.
MKS 84100HP and BRemote2 receiver in semi-waterproof boxes. 4x6s batteries (EVE INR21700-40PL) so I can easily charge them in the car with cheap and tiny charger s. I put the batteries in freezer bags as secondary protection in case of minor amounts of water inside.
Motor is Flipsky 6384 with a modified pod that was shared by bzhwindtalker. Modified it so it had enough clearance for the wires of the Flipsky motor and opened in the back to easily get the wires with connector in and out.
Board includes a small alu plate connected to the ESC to get the heat out.
Next steps are to reduce weight by trying the 6374 and getting rid of the alu casing of the ESC
And I will build some 4s batteries and see if I can save some weight that way, without loosing too runtime.
WHat is the weight breakdown of the system.=? Looks good. Been thinking of a build like this over the winter.
Board including hatch, ESC, receiver and cable is about 4kg.
The batteries are about 440g each, so 1.8 kg
The motor is 1.1kg
Don’t have the weight for the pod or the foil.
So instead of getting rid of the case for the ESC, I got one of the 75200’s they sell really cheap right now. The cable layout also works better for me.
With a simple 3D printed case and alu bottom, this saved 220g compared to the 84100 with it’s heavy alu case.
Also fixed up a quick case for the BRemote2 RX.
Tiny summer swell in Finistère.
Foilassist makes tiny swell surfable.
Blessed conditions :innocent: where is the spot?
I feel like it’s Penhors
That looks like a dreamy session!
Seriously good guess with almost no landmarks in view.
Is just a few parking lots further south, maybe 2km.
Unfortunately back home now.
Don’t think I ever had so much tiny swell as we had this year.
Would have been pretty sad without a motor.
From what my watch recorded I used 61 battery charges, with a total of about 338 Km on the water.
Almost no issues this time.
Pretty happy how this worked.
Our last evening was one of the rare days when everything aligns, perfect tide for the spot, no wind at all and ok sized swell.
Makes departure both easier and harder at the same time.
So sweet, dreamy and chill! Lovely video and a really cool set-up.
That are insane stats and time in the water :scream:
Living 5 hours drive from the nearest spots with barely usable swell, I have to make the most of it, while I can.
Was super happy I did not run into any issues during that time.
Got some new toys…
Was a bit of work to get the stretch pod to fit the slim mast, as the design was failing for chord<119mm, but got it fixed.
The foils are just amazingly good.
Not sure which part is responsible.
But for the 750cm² I had to adjust my VESC settings up. In chop I could only get that one going with a wave pushing.
So had to increase current limit from 100A to 120A and power limit from 1900w to 2200w.
Guess the positive streak can not go on forever.
Turned on the setup this morning and created a lot of black smoke.
Happy this happened on land and lucky only the ESC died and the board is undamaged.
No idea how to potentially deal with this when in water.
Wow, very ugly. Did this happen right as you connected the battery or did it seem to spontaneously start smoking?
I had a 75200 like that short a 14S battery a few years ago. No smoke from the vesc, just a blown fuse.
I suppose this can make a case for an easy kill switch. Those used to feature on efoil builds but haven’t seen them on assist builds. Harder to integrate into a smaller space.
no, this happened after a while (>30s <5 minutes).
I heard an odd clicking sound when connecting, like a relay clicking and in hindside, I should have checked, since there should have been nothing that could have made that sound.
This was luckily no full short, batteries were not even slightly warm after.
I assume there must have been water inside my box that houses the ESC and the components on the undersided just slowly burned through.
Actually it was a different problem. The motor for some reason did not deliver enough power anymore. On a new VESC detection the internal resistance went from 50ish to 100+, so its a hardware error.
Took the spare motor and am down to 2000w again even on the small foil.
Getting some nice late summer conditions here.
Last morning in the lab. Conditions have been unreal last few days (but for the algae at times).
