Hey all,
Before I start spending too much, I wanted to see if i could attempt a build using a 6374 190kv Outrunner and VESC I’ve had around for a while. I’m not intending for this to be the cleanest build ever, just seeing if I can get the thing to fly with a motor I already had! The motor is rated for a max 80A / 3150W.
The board i’ll be using is a 100L surf/SUP with a Large Gong Allvator foil. I already have the mast mount designed and printed to fit the motor. My biggest question is prop design, and recommended battery system. I quickly drew up and printed a 7" pitch prop that’s around 150mm diameter and 30mm depth
Big question: would this motor be able to lift this board considering high volume and large wing? If so, any battery and prop suggestions would be greatly appreciated!
Worst case, I already designed a second mount for the Flipsky 65161 using the design specs on their site. If the outrunner is a bust, i’ll most likely go with that.
