Audi e-foil design
Greetings from Türkiye. I designed the Audi foil just for hobby purposes.
RE2
RS3
Great.
Why it is called Audi?
What more can you tell us about it?
It’s called Audi because it was originally designed by Audi :smiley:
Thank you, I think @ludwing bre gave the answer.
You also have to design the jet engine, that‘s the hard part I suppose. I had the chance to test it and I really liked it.
I’m working on the motor design now. I don’t know what kind of motor they use. If I knew what motor and ESC they used, the process would go faster.
Actually I want to install a Sifly or Waydoo style engine. I don’t know if a jet engine is efficient.
Hi. Looks great. Any chance of getting a plan and elevation will dimensions?
hello hello thank you,
length: 1760mm
width:720mm
height:130mm
height difference between the top and bottom of the surf is 150mm
I’m not sure if the dimensions are correct, maybe someone who drives an Audi can tell us the real dimensions.
@hsyn you should reconsider blatant copyright infringement. :face_with_raised_eyebrow:
If you happen to make something that looks similar at small scale then the company likely would not care. Start using their name and trying to make an exact copy might get their attention.
I also did it 2 times :slight_smile: but scaled it down to my needs.
One small with 62 liters, a bigger one with 86 liters
I really like this shape.
Only at the the back I don‘t wanted the round shape. I modified a little bit.
The sizes of the original boards are listed on the original homepage.
With the available pictures you can scale to the size you prefer.
What’s the point of copying it, if i might ask? It’s just a board, an Audi board, whatever?
I honestly don’t get it, seems more fun to draw your own?
I like the shape. Good to have something to start from. Id be hot wire cutting so not much chance of a direct copy. Im about to launch my first build. I have modified a sic mako 5’ 7" 105l. They were on sale price here in nz.
I have a lot of respect for board designers, alot goes into subtle curves and angles that only trial and error can get the finished product performance optimized
looks great congratulations What brand and model of motor and driver did you use?
I made 3 different designs and production. I really liked this design for the sake of variety.
Thank you
I will make my first model with a CNC router and then get a mold, but I will make serious revisions to the design.
