Here are the files to my Fully 3D printed Foil and Mast. I have many pictures I can post upon request of angles I printed them.
Mast 1 (top part of mast with Mount)
Mast 2 (middle part of mast)
Mast 3 ( bottom part of mast)
Mast 23 ( mast 2 and 3 together held together for better support while printing)
Mast 23 worked the best on my CR-10
Foil wing Left and Right I printed countless ways and it kept failing until I tried this angle.
Austin, I really like your design! I looked at your library of parts on grabcad and it wasn’t immediately obvious to me which of these I would need to print and equally important how you envision assembling them together. Did you fiberglass or carbon fiber your design? Or plan to? Thx!
I plan on fiberglassing all of it together. Right now its just glued together. There are three pieces to print for the Mast (Mast 1,2,3)
and the foil has 3 or 4 parts to print depending on what type of printer you are using. My CR-10 has a decent print box so I can print half of the front of the foil at one time
To be honest I don’t thing this 3D printed setup will work. How do you handle the push force in the mast? Carbon or Glas is not good in taking those. For the fuselage I also think it will break. Last year I made one out of 20x20mm wood, an it broke immediately
Atriay11, we have finished printing the mast (mast2+3 took 23 hours !), now printing the fuselage for only a couple of hours.
We are surprised by the length of the mast, ain’t for rookies ! So we were thinking about keeping only the first 2 parts, and forget about the third part so that it is reasonably easier to start experimenting and flying. Mechanic efforts will be weaker then too.
Glad to hear its coming out well! Right now I have gorilla super glue holing the parts together before glassing it. I’m excited to hear you are covering it with carbon layers. I’d love to see how that turns out, please share some pictures. If you plan to shorten the mast length I would skip MAST2, because Mast 3 has a non hollow bottom that will help adhere to the fuselage better.
