Apologies if this has already been answered but I couldn’t find anything searching.
Does anyone have a pod for a Axis High Mod Carbon Mast?  I just ordered one and was wanting to print a new pod.  I have the pod of the aluminum mast and it works great!.
Would this work?  I think this is for the original carbon mast.
              To be clear  it is the high modulus not the ultra high modulus.  It’s the same width the whole way down
              I would recommend the nano + insert. I know there is a insert for it in the forum but can check for you in a week earliest.
              Do you have a link to it?  I’ve printed pods in the past I just figured the profile of this pod will be different than the aluminum.
              I ended up building my own mast profile and making a pod for the 6384 motor.  Feel free to take the profile and apply to any other motor too.  The pod is slightly bigger than the mast as I put 1 layer of electrical tape over the mast where the pod mounts for protection.  This should work for the high mod mast and the regular carbon mast
Tinkercad link (full pod)
STL Files are here (split the pod into front and rear sections).
