Banebot gearboxes and motors made in USA
Your board will barely move with brushed motors, for a little while! Pod choked by carbon dust, lots of heat generated… maintenance… I work for a company that produces also marine thrusters, believe me, r&d have invested a lot to reduce brushed motor from the lineup. They are simply cheap and way cheaper to make run. End of pros. Huge list of cons!
The problem in Efoil is not only to lower the motor rpm, but to have the right output shaft speed (propeller shaft) with the highest torque possible. This is where direct drive lacks and to make it up require the utilize of big diameter (hence leverage) outrunner (with all the cooling difficulty).
Brush motors are 20th century’s technology. Anybody is try to move on asynchronous or fixed magnet brushless, where tight budget ain’t a problem.
Asynchronous would be interesting, there are very nice and refined controllers for those motor but I’m afraid sizes vs. power can’t match syncronous brushless (like ours).
