Has anyone tried to apply a layer of Epoxy covering completely a LiIon battery? Any problem? Heat dissipation?
I have read a similar topic on waterproofing a LiPo but with little feedback.
I understand that there is no way to repair the battery once covered by epoxy but I think that the biggest risk is flooding more than a cell failing and having to be exchanged.
Any thoughts on this?
It is better to fill everything together with BMS with a two-component heat-conducting compound for electronics. It is easily removed.
bad idea because the resin is brittle and will crack when deformed
I filled them with the Bluetooth module and ESC.
And the remote control screen. It is transparent and not transparent.
Transparent for the remote control. For esc, it is not transparent. I bought it at a local electronics store.
