Hello efoil experts,
I have recently been able to test my efoil on the water. Good news is its flying but bad news is the 6800 bearing at the top of the stator is breaking extremely quickly. I did only 2 sessions of ~40 min and it broke each time !!!
Here is the broken bearing ( motor is not waterproofed, it has only been sank in CRC 6-66 then rinced in fresh water after each session but seems not enough)
I am wondering what is causind such quick failure:
Is it because of the shape of the base of the shaft that is pushing direcly on the bearing, I forgot to put a washer betwen it and the bearing to spread the axial load ?
Is it because of weak bearing : I directly change the original bearings with these one
https://www.aliexpress.com/item/4000201499767.html?spm=a2g0o.order_list.order_list_main.21.23325e5bb0SaAi
Strange the other 6800 bearing on the other side is not breaking -
Is it because the propeller I printed in PLA is unbalanced ?Tthe print has little imperfections, also I covered it of epoxy to strengthen it. Propeller is light so could it break the bearing so fast ?
Is it because I missing some pieces in the motor. Here they are:
But I have still a small gap:
By the way do you know where to buy the “golden ring”
- Is it because there is a direction/way to insert the bearing to better support axial load ? I can see from the destroyed bearing that it is not symetrical:
I am really lost. Could you please help me to solve this issue
Thanks in advance
