Best "Kit" for efoil in 2026
Looking to get thoughts from the group on what is the best “kit” as in the simplest DIY option out there. I’m looking to finally do my first build. I’m leaning towards the Flipsky 6384 or the 65151, and 75200 vesc, with a Gong V3 foil and DIY battery, but looking to see what others think are the simplest to setup out of the box and strap together. Taking into consideration some of the newer options in the market. Also, bonus if it’s easy to get in Europe.
How much of it do you want to build?
I would argue the easiest approach right now would have to be taking the Riift tracks and just glassing them into a board. Then making a waterproof housing for the battery, potting it and using an IP68 ESC. Simple, fast, minimal build time on a board which I have always found to the the biggest pain.
For someone who has actively participated in the forum for 8 years your question is a bit absurd.
You don’t even mention your use case or what you are doing for a board. :enraged_face:
I could answer your “simplest DIY” by saying buy a commercial Fliteboard and slap a happy face sticker on it.
Riift looks like a real easy option, but I’m also trying to do a budget build and looking more at a regular Efoil, rather than a boost assist. Lots of flat water where I am. It would be a good option if they had a longer wire option. But also if seems like I could just buy a waydoo for the cost of their system.
I actually don’t mind building from scratch, but it seems like Flipsky and Maytech both have some new options, even jets that are pretty new and could be good options.
Fair, I admit I’m a long time lurker. But currently in an area with a lot of flat water and think an Efoil would be a great way to get around. Might even be faster way to get to work. But looking to make a budget DIY Efoil.
Hard to beat a used fliteboard. The hatch on them is exceptional and my 2 never leak a drop. Then the flipsky kit with the 65161 and a fliteboard prop. Then all you need is a battery. I use gong v2 curve L and its great 85cm al mast. Great sport just do it. Building a good board is quite hard. I have been building windsurf and surf boards fopr a long time and I went for the fliteboard hull only. Super good bang for you $$
I think you missed the point entirely. Buy the Riift tracks only, then make all the rest yourself. The larger tracks have enough space for a 14S4P battery which is identical size to the Fliteboard sport battery. That will easily get you an hour on flat water. Another option would be building a similar set of tracks to Riift yourself if you even wanted to eliminate that cost. Then using an aluminium extrusion enclosure off Aliexpress for the battery and potting it to keep it waterproof.
most easy and cheap, buy wingfoil material (GONG ) 2end hand lots available . make a box with battery and esc on top of board with straps. flipsky motor and remote on mast . e voila you can go efoiling. 65151 en 75200 are a great choice. remote vx5 good choise.
