For sale used Made in Germany by Lehner Motoren Technik BLDC motor Torqstar 3 (7050), 24 KW, up to 20 000 RPM, outrunner with water cooling in excellent condition. 5 windings, 20 Magnet Poles, 12mm shaft. Fully tested with VESC and ESC, used only for 3 hours. Custom industrial construction edition with ceramic bearings which are designed for 100,000 hours of operation, increased diameter tubes of water cooling for better heat sink, temperature sensor.
Comes with 6 month of warranty.
Shipping from EU by express courier service.
Price: 650 EUR
Hi
Just one question, is the black cable a temperature sensor or even timing?
I have two Lehners a 7050 and 7065, but no additional cables.
By the Way, I think one of the best motors on the market.
You are right, this cable is temperature sensor. Because it’s custom industrial edition, not standart one, it equipped with the sensor. You can also notice that the diameter of the water cooling is not standart, also increased - for better heat sink. Moreover, it has special ceramic bearings for smooth long-life operation.
And yes, I agree that it’s probably the best motor in the market, especially in this version.
Thanks a lot. Bye Fabian
70mm diametre is not far from the 65mm one used for efoils.
Looks tailored for a esurf, is it possible to mount a propeller on the (rotating) bell though ?
The motor does 20 000 RPM! I think it is a bit of an overkill for an efoil.
It would be nice for a jet board
Yes, you are right, if necessary, an air propeller can be attached to the spinning rotor for cooling. There is a mounting screw for this.
The motor develops its power starting at 12,000 RPM, so it can be used in any application. It is usually difficult to reach the maximum RPM under a good load.
UPDATE: NOW THE PRICE IS 400 EUR
With courier shipping from and to EU.
There’s two options available: aircooled, and hybrid air with water. Tell me which version you need when purchase.
I am interested in a hybrid version. I’m interested in 7050/6 Price 400 €?
