I can make custom board for you, or sell some substandard boards.
volume 68 Liters
dimensions: 140x60x15cm
XPS core, FiberGlass 3 layers, epoxy resin laminated, gelcoat, painted!
blank board for efoil for cnc cutting by yorself available. Ship from Russia all other the world. Look at some finished boards as example. IMG_20210419_181556|690x388
big size good for novice, but then you know how to ride you look for smaller and lighter board because smaller board more agile. carbon does not provide significant advantages in comparison with fiberglass; from the disadvantages it shields the radio signal. the carbon version will cost around $ 2,000. we can discuss in more detail in PM or telegram @artfoils.
I have model of board 110 Litres, 168x70x13.5cm FrankBoard-rev2.pdf - Google Drive Fusion
this is not a serial model and will not be manufactured in a matrix, so we will be doing a lot of manual work to fine-tune the shape
