anyone know offhand what the bolt sizes are for the front and back of the flipsky 65161 ? and the prop shaft thread?
thanks in advance!
thanks in advance!
Found the answer here if anyone needs it:
Just an update in case anyone else pulls this up at the top of their “65161 bolt size” google search results like I did–
I realized when I went to mount my prop duct that the waterproof 65161 with the upgraded shaft seal has a different layout on the front side. The back of the motor with the four M5 holes is the same.
On the front the waterproof design has 4x bolts installed with a 3mm hex socket on the face and then along the sides there are four M4 sized holes that have about 8mm depth.
Now looks like this with 4 bolts:
Instead of old style with 6-M4:
