Interesting point. There might be some weird fluid dynamics issues there too.
How is yours build going? Looks like the FR prop? Did you manage to get flying?
Quick update. I have very little time because two young kids, but did manage to get back on the foil this summer.
Some tweaks WRT OP:
Results:
Open questions:
— At this speed, you should be on foil already. I suspect it could be the foil set you are using. I am using a large 2100 cm2 front wing and I could get on foil at around 10 - 12 mph.
Hmm. I’m using the 2019 Naish Thrust Windsurf foil. Just looked up its specs, seems substantially smaller surface area than yours (1220 cm^2).
Also expecting a FR prop soon (it shipped!), so will try to see if that makes a difference
I would assume the area is not the issue, more the shape of the wing - no idea what “Modified Delta Planform” means; but it’s clearly not saying “high lift” as for most of the others…
A lot of people are using the Gong curve MT which has only 1150cm² which flies aroun 16-18km/h.
