Thanks a lot Ludwig for all your work, I tried my tow today, it works with Flipshit FT85BD, I was so happy ! Cooling is OK with a radiator.
I have a few questions :
What is the purpose of the gear selector (in what kind of riding is it useful)? Is it only for the first session, to find the right gear ? (I will change parameters to start with the good gear)
I found the trigger too exposed (so, dangerous), I saw a solution on the forum, printing another housing, I haven’t found it again yet.
What is the correct logic for steering the tow? Push to the right to make the tow move to the left?
If you wanna ride at lower speed or power, you can choose lower gear, but if you wanna pull someone heavier or something you can increase power. you can disable gears all together if you don’t want that
Check in the Future Topic, for example this post: LINK
For me, left = left, right = right You can invert steering in the settings
Vesc Limit is phase 90A. I start with the high gear, then i switch to the low gear. During foiling, i dont need more than 45A. So i can use full Throttle length. Well, irl its 40-100% (20-45A). Thats 60% useable way.
If i wouldnt use Gears, during foiling i would only use 22-50% of the Throttle. Thats only 23% useable way.
So changing the Gear makes the Throttle way less sensitive and more intuitiv.
@V_S Are you saying you switch gears after you get on foil? Is this for eFoil, Foil assist or Tow Boogie? It wouldn’t be possible for me to switch gears while on throttle with my diff steering tow boogie.
@poloswindsurf With my Tow Boogie, I also use gears for Current control. I default to gear 6 for most of my session, but as the battery starts to get low, I switch up to gear 7 for a little extra power. This way I can improve technique by getting on foil using only the bare minimum of power required.
I start in the high gear with full throttle. Once the board is planing and has reached about 20-25 km/h, I switch to the lower gear. At that speed, the power is just enough to keep the board planing (around 20 km/h). Then I kneel down or stand up, shift my weight, and get onto the wing.
(sorry if this is the wrong topic to post this in, or this has been answered elsewhere - I did search before posting)
I have the Bremote V2 kit for tow boogie, and I have an opportunity to mount the external antenna higher than on the top of my pelicase.
Does anyone know if the antenna is waterproof as it comes or if it needs to be mounted on a flat surface to make it waterproof (so that the cable route into the antenna is kept dry)?
Feeling really stupid here: can someone else try my Rx Base64 strings in the “C-Struct to Table” page ( C-Struct to Table )
Nothing happens when I use them
(the string from my Bremote V2 Tx is working fine)
Here are the strings that I have saved that I have been trying:
Rx:
From 24/09/2026 - AgABAAAAAQAyAAAAAADcBdAH3AXQBgDCgAAAAEAAAACAAEAAAAAAAAAyEEAACBBAAAgQQAAoEAAAAxCAAA0QgAANEJBjhw8AAAAAOgDAQABAHO6DEbHwA==
After update to V2.2.8.1_Integration_Rx.ino.bin:
Rx
After inverted motors for steering (27/09/2026):
AgABAAAAAQAyAAEAAADcBdAH3AXQB+gDCgAAAAEAAAACAAEAAAAAAAAAyEEAACBBAAAgQQAAoEAAAAxCAAA0QgAANEJBjhw8AAAAAOgDAQABAHO6DEbHwAA==
