Hi guys, do you think that I could repair this connector?
It’s as easy as change the plastic lid?
Can you get inside the case? If you can, just replace the connector
If isn’t enough to change the plastic get inside later I will need to re do all water proof . This a PWR battery, the one you can sumerge and still working
Looks like the pin is also damaged - how did it happen?
Cleaning with fresh water, it hit something
