Hi from Italy,
I spend a lot of time reading on the forum, i want to build a budget friendly jet board.
I had in mind 2 possible option:
- Single jet configuration:
Board: not sure yet, i was thinking about some short fish shape board, maybe custom ones…
Motor: single Alien power system c80100 350kv outrunner motor
ESC: FOCer 2 esc, i think that with adeguate cooling and some mods i can push it to 110A
Jet Drive: saw this on thingiverse Water Jet (80mm) by WackyParts - Thingiverse but im searching more
documented design…
Batteries: 13s4p 21700 molicel pack
2)Dual 50mm jets configuration:
Board: same to single jet config
Motor: 2x Surpass hobby 56102 600kv motor or maybe 2x surpass hobby 55113 550kv
ESC: same 2x FOCer esc
Jets: 2x toto44 50mm jet units , i took this from another thread, they seems working…
(STL file Water Jet propulsion unit・3D printable model to download・Cults)
Batteries: 12s6p 21700 molicel pack
I read a lot about the second configuration in a previous thread by Kian, the second config seems working pretty well and since its already tested im more confident about it,
however i also read about single jet configuration and since it may be cheaper i ask if someone have some experience in the topic, have someone build a board with single jet before?
If yes, what are the correct part to use? if not, based on your experience, can my single jet configuration work? Feel free to suggest more appopriate part and thanks in advance for those who will help me.
