The propeller had to be refined a little!
Here I think,whether to print for a given propeller duct?
Hello Anatoly, can you tell us what is the gear ratio of your planetary?
Where in moscow are you located? From time to time I travel to Moscow jobwise. Maybe we can have a beer together?
The gear ratio of the gearbox 4,25: 1.Hello Toto44!Beer drinking of course you can,it would be a desire and time.But I don’t speak English.What about you?
Hi @Anatoly, I speak Russian and come to Moscow frequently as a part of my job. Is it possible to meet and share ideas? I usually stay near Sokolniki. What neighborhood in Moscow are you from?
We build efoil,and it turns out a music box!
ahahhaha. Nice music
Do a starwars theme pls
Seen in August 2018 here by @ArtemkaMAX also from russian vaz 2110 car :
@ArtemkaMAX: how is your system going. Did you succeed ?
Better availability but also more expensive starter kits in the Bosch and Valeo catalogues:
Hi!Yes,half a year ago,in this tape I found this solution to use the starter gearbox!Your information on gearboxes I also studied in detail,thank you.We communicate with ArtemkaMAX at our local forum.Thank you once posted it here,maybe someone come in handy!
Spun up to 4200 on the propeller!The temperature on the keys is 80 degrees!Readings on the scoreboard are not correct,the code is damp,we are working on eliminatin.
