Hello everybody,
I’m building an Efoil from scratch. I plan to use a 3D printed core for shape, then reinforce it with carbon fiber. I have a rough CAD assembly for my plan so far. I’m looking for feedback on the design before I start the building process.
I’ve spent most of my time working on the mast-to-fuselage connection. The plan is to clamp the motor around the mast, then have the fuselage wrap around it and screw everything into the mast, and finally cover the fuselage with panels to maintain hydrodynamics. The bottom of the mast will be aluminum for the screws to tap into, and the screw holes in the fuselage will be filled with epoxy and redrilled.
I want to mount it between the front of the motor and the prop guard, but this would leave me with a weird joint. I could connect this to the main fuselage and run it under the motor if need be, but I’m trying to avoid that for simplicity and hydrodynamics. Any suggestions?
I’m looking for any feedback on things to change before I get too far.
You are absolutely right, not reinventing the wheel would be the smartest approach, and just buying gear and modifying it would be the easiest, but my goal is to save money. Your suggestion isn’t lost on me, and I’ll probably regret this choice later, but this is the plan for now. This week’s plan is to make a test piece the same way I’m planning to make the rest.
Highly appreciate your determination, and as far as I can see you seem very knowledgeable with the drawing part. But just saying, a gong v2/v3 mast is like 70 bucks and wings are out there on used marketplaces for pretty decent prices. But I’m looking forward to your self made wings! Looks like a very solid project.
