Cable glands source
Anyone know where to find the cable glands used in the flying rodeo motor?
Thanks!
Lift and FR Motor are using the same system.
It is custom made by ODU based on the LAMTAC System.
In my last/new build I am also using this motor and ordered the ODU LAMTAC Connection System.
Thanks, I assume nowhere to buy those exact ones the.
I building a setup I hope to use for different things efoil, towfoil, foildrive. I was planing on running the motor cables into a waterproof box with cable glands. Everything else would be inside. Maybe I should have external waterproof connectors? Any other ideas?
I wanted to be able to take the motor off the mast and potentially reposition as needed. Currently have flat copper connectors which I can directly connect to my esc and will pass through the mast.
WetLink and the WetLink Penetrator look pretty good:
