Hello everyone, I have a question regarding the internal wiring of an ESC, for example the 75200 from FLIPSKY.
A few days ago a little water entered the compartment where I have it and at the first spark I stopped and got out of the water paddling in the traditional way.
With luck it could only be one of the capacitors that is damaged.
I will try to replace the 6 condensers, the cost is relatively low. I don’t lose anything by trying. But I have a question. How are the group of capacitors connected to the ESC? The group is in parallel to the battery input?
the red line joins the same point of the circuit?
thanks
