I built a 12s12p (42V, 31Ah) 2600mAh battery pack that I want to charge. A BMS is connected.
I tried to use my little and lightweight ESK8 charger (41V, 2A) charger and I have the feeling that is doesn’t charge. Neither directly on the plus and minus nor via the BMS.
Hahaha.
This is really true. In the years of Lipo charging, I have made also bad experiences. This is why I charge the foil battery only open air on concrete.
With the DIY Foil, questions arise, that I never needed to ask as in the RC world, you have charging programs with built in balancers.It is self explanatory. Here you need some more background.
Can’t charge a 12s battery with a 10s charger (if that wasn’t clear already?)
12p of 2600mAh is 31.2Ah so it would take more than 16hours to charge at 2A. You can google “CC-CV charging” if you want to know more about the charge profile.
