CnLinko LP16 with 8mm bullet connector - opinnions
Inspired by @f16model and Quarantine Efoil and because I didn’t find links to ready cad files I started modeling CnLinko LP16 connectors for motor wire connectors.
This is what I came up with:
What do you think? Could these be used as motor wire connectors? I have to check that the bullet connectors slide deep enough.
At the moment small plastic parts are printed PLA. What would be the best material for printing those?
That’s nice, I only work with PLA and TPU (elastic) filaments, haven’t others, I’ve managed to make 3D printed parts waterproof by sanding them smooth and coat with either cyanoacrylate glue, 5 minutes epoxy, polyester resin.
Hello! Can you please send the files for printing ?
Hey Ivryl,
Very cool idea, I also really like the Cnlinko connectors! Unfortunately, they don’t sell extreme current ones so good idea! Unfortunately, the bullet connector you picked isn’t really capable of many connection cycles. I would go for one with springs instead of the one-piece brass type, the newer banana plug idea? If you want to use them on the wet site I would go for the 120A Surloks those are capable of many more cycles and better rated for the current.
I have to make little adjustements on the thread. Once I get it nice, I will share the files.
@Kwinty: Do you mean something like amass xt150 connectors?
thank you very much, I will be waiting
Here are links to STL-files:
https://1drv.ms/u/s!AnKIH99XNtqJ8Sj-ugEgBCkGJG5K?e=2zxZda
https://1drv.ms/u/s!AnKIH99XNtqJ8SuWlVw3-TxapNNQ?e=Z2dnbD
https://1drv.ms/u/s!AnKIH99XNtqJ8Se7YnsHyrfBZNxI?e=4St05q
https://1drv.ms/u/s!AnKIH99XNtqJ8Sp4zLhZ57J3PdZH?e=r7kUYr
https://1drv.ms/u/s!AnKIH99XNtqJ8SmGzlGEn6_hIiJs?e=ZxfUMJ
I just found a flaw in my plans and those files: connector housing don’t lock. New versions are being printed at this moment. Hope they solve the issue and I will send new files.
Here are new links to STL-files
