Combined Resources for Foil Assist
Yes I meant to reply to someone else.
I understand your comment, and it was good.
this was structured to help with orientation and FAQ, but I agree with @lishine it is mostly unnecessary with ChatGPT. If you make a choice on specific gear, ask Deep Research to find out if there are any issues, and decide if you are competent or patient enough to deal with them,
You should not have gone VESC on first build, added that below:
This is probably your mistake. Why did you create a new unexplored build? My first build was an exact replica of something that seemed easy, and even then it had tedious aspects around ESC config that I thought I would recommend avoiding.
I think your judgement of others is a little misplaced.
We are all different with different skills, tools and needs.
It’s a comment based on this
My intention clearly is to improve the accessibility of knowledge to avoid situations like yours, and maybe there is an update to the pointers, avoid VESC entirely as an example. I haven’t used one yet, but it seems extremely tedious
I just programmed a new build using VESC Tool and used ChatGpt, it was easy and the result was perfect.
I just haven’t got the ERPM limit right yet. ChatGpt was too high and has taken another guess, that I will try next time.
