Today I prepared the stator for epoxy. I removed the wire insulation, covered the shaft bearing and threaded holes with e-tape and marked how far along the wires should have epoxy using the rear mast clamp.
The Maker Lab at SCU drilled holes in the motor cap for me to allow the wires to enter the clamp. They also 3D printed the mast clamp by V_S from the Volker build.
I will be filming the epoxy painting process for the stator and clamp parts. Stay safe and stay tuned!
