Hello everyone, this is my first post. I am 27 years old and live in Switzerland. Since I want to start foiling as a hobby, I would like to build an efoil. I believe this is a great way to learn.
I find the concept of the FoilDrive Gen2 very appealing and I am strongly inspired by this design. However, I have no experience in building efoils, batteries, or other RC-related things. Professionally, I am a mechanical design engineer and therefore have some knowledge in mechanics, but not so much in electronics.
This forum is 99% of my information source, but it is difficult to keep track of everything… many posts, builds, ideas, and opinions.
For this reason, I have developed a first, very rough concept and would like to hear your opinion on it.
The main body, which will take the load, is to be milled from an aluminum block. This will be sealed with aluminum covers and O-rings. The aluminum covers will be glued with end caps from the 3D printer. To make the PLA watertight, I would use Dichtol, an impregnating agent to make 3D prints watertight. I plan to have the aluminum parts manufactured by PCBWay, and I expect the cost to be around $600.
I would use the same components from @hangloose :
- 6384 120KV BDUAV
- Flycolor Flydragon 150A
- Molicel INR21700-P42A 4200mAh (8S3P config)
- Flipsky Remote VX3
The ESC should be cooled well by the aluminum body. Due to space constraints, like @hangloose, I have to desolder and reposition the capacitors. The battery should be inserted like in the FD2 and connected via a 2-pin connector. Regarding the connection of the motor cables, I am still unsure. I would like to run a 3-pole cable through a waterproof cable gland and then connect it to the ESC inside using a 3-pole connector. The covers at the front and back will be attached with 4x M5 screws.
Dimensions approx. 525x115x70mm
Here are some screenshots:
