Hello,
I bought a Flipsky 75200 with an aluminum case. I plan on applying conformal coating to the board.
I have not conformal coated an ESC before, so any tips or advise is welcomed.
- One speed bump I am running into is how the boards are stacked. Is there a way to safely separate the boards?
- do I just desolder the pins on the top PCB?
- should conformal coat what’s under the white paste? Or is the presence of the white paste adequate (does not need conformal coating)
