Can someone help me how to connect the receiver to the Vesc? Thanks
GND → GND
5V → 5V
RX → TX
TX → RX
If you don’t know which wire is TX and which is RX, try connecting the two wires randomly, and if that doesn’t work, swap them.
I don’t think these are the correct pins. Please check GPIO 1, GPIO 3 or GPIO 16, GPIO 17. You’ll need UART, not USB.
These excerpts are originally posted by Manta Foil. How do I find out the correct connection?
If this is a Mantafoil receiver, ask them.
There is no answer from them, unfortunately.
