Damaged Fsesc 75350 flipsky components on top
Does anybody know which component this is on the fsesc 75350. It fall of and is gone, because it is so tiny no chance to find it on the floor.
Thank you
Looks to be the same as the other ones on there. Can you see a number?
Most likely a ceramic SMD capacitor.
How did you loose it/ Fall off?
The problem is that on chinese components they often got no number. I guess it is a capacitor but do not know the specs. Only the Size is clear. It cracket of while getting it into small housing. Seems to be no good solder. Worst thing that I lost the component and can’t measure it now.
Which one of the other capacitors should have the same capacity?
Ask flipsky support.
Since you have a good schematic I think you can figure out which value it is by finding which IC it is connected to with a dvm.
Generally, take the largest capacitor in capacity that can fit there, while it’s voltage rating must exceed the operational voltage at that part of the circuit.
There are also special low esr capacitors
