I would like to install a wattmeter or something else which could give me data after a run.
Thanks to help me.
in e skate it is not by bluetooth module mert.pro which is super complete but which connect on ke port uart of the Vesc … but on a ESC I do not know if it is possible …
A very good solution, but expensive.
If you have basic Arduino experience you can diy a datalogger using a Mauch Voltage/Current sensor and a Teensy 3.5 (built in SD card) fairly easily. I use these in my setup, although I haven’t actually foiled yet.
@g.gregory8 I could try but I have not the knowlege in Arduino. Do you have sheet or drawing of your model? That is the reason why I try to find something in the shop.
