I am not deeproot himself but from the above pictures I can tell that he uses this Flipsky Vesc6 based esc. (at least I think he uses this)
https://flipsky.net/collections/efoil-products/products/high-current-fsesc-200a-60v-base-on-vesc6
You can also find it on Aliexpress and bangood if you search for it.
Thanks a lot⦠but whoauuu⦠$300
I think Iāll try to find something under $200.
Thanks again
Denis
Hi DenisJ, yes 99kg is correct. I got this vesc/motor package here: 200a Single High Current Vesc6 Speed Controller + Ip68 Waterproof 100kv 120 Kv Motor 65161 For Electric Surfboard - Buy Electric Surfboard Esc,Surfboard Motor,Efoil Esc Product on Alibaba.com
Only took 7 days for shipping to the US!
It works great, no issues. I have about 15 hours on the vesc now. I would not recommend getting a vesc under $200. If anything spend a bit more and get a nice vesc. Good luck!
Iāll see⦠I have time until next spring
Thanks a lot for the answer.
Denis
Here is the link of what you ate looking for : https://fr-m.banggood.com/Wholesale-Warehouse-Flipsky-High-Current-FSESC-200A-60V-ESC-base-on-VESC6-for-E-foilers-Underwater-Products-wp-Cz-1476019.html?act_poa=SKUB95777&cur_warehouse=CZ&rmmds=detail-bottom-alsolike
But not sure it will work because some have the wrong resistorsā¦. Hope to you to test but saving money on Efoil does not work nicely all the time
Do you know anybody that have test it and had problem with it please ?
Thanks a lot for the link
Denis
Have you made anymore changes or is everything still as good as it looks? Do you have a picture of the water port exiting the board?
