How do you all clean and protect your cable ends after a session in saltwater?
ReelX or dielctric grease like Permantex? Re-apply after each session?
I don’t use it. But applying every time is the foil drive way.
There are degreasers that will take it off but they can also harm the seals on waterproof connectors so you need to be careful with them.
I use connector cleaner periodically which you also need to keep off the seals.
