80A@125V/200A@50V
Max Amps: 80A
something is wrong there…a BLDC motor is limited by max amps/windings, not by max power (80*125= 10kW = 200 *50). So might be similar to APS 70100 and 56200 motor (also 80A).
Protect Feature: Waterproof
Grade would be nice, “sealed” and “waterproof” are often used for splashproof (IP64 or IP65)…
Looks like there are grooves for O-rings, but screws 1) not clamping them and 2) behind the sealing
350$ +30$ Shipping
*1,19 Import Taxes ~ 400€
(APS 56200 is 230GBP ~ 350€ incl. shiping & tax?)
Bearings description is missing, wouldn’t be p&p without thrust bearing/ angled roller bearing…
Also the 2mm hole for shear pin is bit small…most likely due to 8mm shaft.
Could be still a good motor for a simple setup. Igus or ceramic thrust bearing could be added right to the prop. Water-tightness has to be tested.
