Hello,
I have been reading this forum for a while and collecting information.
I have been working on a custom DPV (diver propulsion vehicle) and I think challanges are very similar to building an efoil.
I need significantly less power but I have not found the appropriate motor yet.
My requirements are:
voltage 36V (can be lower if it is necessary)
speed 1000-1200 rpm
torque 10-15Nm
(~1000 - 1500W)
Low KV motors generally have much more power that I need and they are a bit heavy.
I found only one supplier : Revolt
But it has too many negative feedbacks.
I would like to have a direct drive motor but I have not found any with low KV and high torque.
Do you have any suggestions?
Thank you in advance.
