I used runtastic, it showed max velo of 13.4 km/h. At 1.7-1.8kW. We drove around over an hour with a standup paddle windsurfboard and the Boosted board. We tried some towing also, it was hard to hold the rope.
Its a little bit strange: If i take the pitch of the prop and the RPM, the props velocity without slip is around 30km/h. The inlet diameter of the duct is 160mm, reducing to 140mm at the outlet which is a factor of 1.3. Divide 30 by 1.3 is 23km/h. 13/23=57%, so the slip is higher than expected.
I could not mount the old drive system, because i was not able to open the nut of the cable plug by hand, so i was not able to test it to compare directly.
Any suggestions how to proceed? Higher pitch? Higher Kv? Vanes?
Hi @PowerGlider Can you please share your design for the motor mount on the fin and the prop closure and spinner cap?
I would like to make the same setup (as alrady mentioned) and try different props and SK3-149KV motor as well.
I think the speed of 14Km/h with 1700wt is reasonable so in order to get more power and speed it will require more prop pitch, keeping the same diameter of enclosure and number of blades (which are 3)
No. Powerglider setup is exactly targeted to solve the hitting problem, since the motor is open to the water after it is coated with epoxi. So water touches and flows through the motor. My hope also that in your setup the prop wasnât optimized. Anyway I will configure the ESC to limit the current to about 80a not to go over 3000wt.
I just need powerglider motor mount design on the fin and the prop enclosure to print it out and try
Hi @Antonbit, great that you and @PowerGlider are experimenting with wet outrunners. I did a similar test with a too-small motor a while ago and I am happy to share my Fusion designs if thatâs helpful. Let me know. See details here: For who try/have tried direct drive with outrunner - #3 by pacificmeister - Propulsion System (Motor, Gears) - FOIL.zone. It was the simplest design of everything I tried or have seen since we donât have to deal with waterproofing, messy heat paste, etc⌠(aside from the motor epoxy prep, which I skipped). Hope you guys get this running!
The RPM is going up directly at standstill, no problem, the electrical system is underloaded.
The old setup was with 170mm inner duct diameter.
I think i will proceed like this: I have two 6384 100kV PG spare motors, untouched. I will rewind one of them for higher Kv, use it for the new setup, and use the 100kV from new setup for the old setup which was always overloaded.
I also have 6384 130kV which is in reality only 123kV. I could also give a try with this 130kV stator on the new setup, but the difference is not so high, and the efficiency will be lower because of reduced length of the usual stator.
By this i would end up with two better fitting setups which i can use depending on the situation.
Only question remaining: Which Kv for the new setup? If i choose 200Kv i do not need to rewind but only to open some winding head and reconnect.
That would mean i have 72 instead of 36A at 13.4km/h and with a limit by the VESC and motor cables of 90A there is not much headroom.
Lets have a look at this diagram once more:
I modified it, focusing on the surfboard and its power demand and my observed battery power and some assumptions:
Hi @powerglider. It is interesting analysis. Does it mean that the surf drag is lower in high speeds? If it is so why the required power is razing faster vs speed?
What is the difference between âdragâ and âpower demand surfboardâ ?
How can âbattery powerâ be lower than âdragâ? are you decelerating? i guess it should be equal while having a constant speed?!
I did try to understand the diagram myself yesterday eveneing, here is what I assume to be shown:
The dotted drag kurve is @PowerGliderâs assumtion of a logarithmic function for drag vs. speed. The blue measurement points are the values for Drag vs. Speed from the original diagram. Those values are drag forces (in kg on the left scale). The bright red vertical line is his mesurment point he described in an earlier post. The power demand surfboard curve appears to be calculated from the drag curve and uses the scale in Watts on the right. If you calculate the power from the drag interpolation in the original diagram ( Power = Force * (distance/time) and converted the drag to Newtons and the km/h to m/s) I get 589W for 18kg@12km/h and 1090W for 24kg@20km/h. This matches the green line for me. @PowerGlider, it would be very kind of you to release your spreadsheet. This makes it easier to understand how you arrive at your conclusions. I can however understand that this is quite an effort. My own spreadsheet is quite âwithout structureâ, so cleaning it up for sharing it would be hard.
Anyway, on the topic of missing motor phase current dependent on speed. I think we are searching for the same basic information here. I formulated it as drop on propeller load(=torque) when the vehicle speed rises. As phase current is pretty much dependent on load torque I think we are searching for the same information. Iâd love to have a model here. In other words I would like to know how the follwoing graph changes with vehicle speed.
Right now I still plan on getting this information through measurement on the moving surfboard, but some model prediction would speed up my design processes. I tried to get a simple model whith my impeller working in CFD yesterday, but I donât have any experience so this is not looking to promising right now.
Hi
it is a lot of work to extract the correct parts, because i made such a lot of modifications in the design process. I do not want to release the complete history, it is a mess. Additionally i adapted some parts by hand after printing. Would it help if i release some stl files i exported for printing?
There are big uncertaincies in my graph. The original measuring data is instable, and the assumptions i made are optimistic. I used my measuring point for 13.4km/h at 1700W and adapted the battery power graph to be similar to the power demand graph, than scaled it by factor 2.4. Very simple approach.
I ordered two props now, which i will cut down to 140mm:
Yamaha Outboard 4hp 5hp Engine Part 7 1/2 X 7-BA
YAMAHA original Propeller 7 1/2 X8 BA
I hope i can build an adapter to swap between these.
I cannot recommend to use a smaller diameter in conjunction with 6384 100Kv PG, because the throughput might be too low. Also props with less blade area, e.g. 2 blade props will propably not work.
I will try smaller props with sk3-149kv motor. (Probably 5 or 6 inch prop). For 100kv 140-150mm this is the way to go. I saw in the forum that airprop has shown also good results in the water so it makes sense to try it
I took some measurement with 250V insulation tester in saltwater. For the epoxied stator alone i got OL, for the assembled motor including the solderings of the motor cables i got something less, hard to reproduce, minimum was around 100kOhm. I covered the soldering with Plastik 70 Kontaktchemie, sometimes i put a fat blob of MS Polymer around it, but made the experience it does not stick perfectly to the wires. It can help to increase resistance and to mechanically protect the underlying Plastik 70 furthermore. Theoretical a value of 10kOhms is sufficient, as it would limit the current to I=U/R=50V/10000=5mA, which is noticeable but not harmful. Such leakages can be caused by very small cracks where the water contact surface is very small. All these tests should be done in saltwater, i just solve salt in the water, so it tastes really salty.
thanks, i guess iâll keep it as is then
the water proofing i did was:
STATOR:
Remove the tubing around the wires
Cut the wires to length and solder the connectors
Cover the wires with some liquid tape between the connectors and the windings
Then apply a few layers of epoxy on the winding (the epoxy i use to make surfboards) end Thickness was no more than 1mm i think.
Then i sanded to get the outside diameter cleaned up, almost back to the metal.
Finally a couple coat of spray urethane to really seal everything (very thin)
after that i protected the wires coming out with adhesive lined shrink tubing⌠that seems pretty watertight. iâm using the same shrink tubing to cover and hold the connection to the wires going up the mast.
ROTOR:
i just sanded the outside smooth and cleaned the inside with acetone. After that, it received a few layer of âappliance epoxyâ ⌠just because it was written waterproof and the can
I replace the bearings with some SST ones, i have come completely open, some 2RS. for now iâm using the open as they are easier to clean / lubricate
I waterproofed my cables by smearing silicone on the solder joint. Then I put a heat shrink tube over it and let it squeeze out the silicone. After it was cured, I added another layer of silicone and heat shrink so itâs overlapping.
