Diy 18650 lithium ion Batterie
Hello everyone,
In this Video: https://youtu.be/Pb7w1uqetj8 I will show you, how to make a 18650 battery pack for applications like : Power Bank, Solar Generator, e-Bike, Power wall etc.The fundamental is very simple : Just to combined the number of 18650 cells in series and parallel to make a bigger pack and finally to ensue safety adding a BMS to it.
At the end of this project, I made a custom 3D printed enclosure for the battery pack.
Actually, this is pretty dangerous. A good and safe battery pack should have cell balancing electronics.
Please check how you the balancing electronics is wiring here: https://youtu.be/fc0MrHOngPI
The BMS job is not only to balance the cells. It protect the pack against schorts, overcharging undercharging etc.
Nice! Now you have it! Good job!
