Yes, I see, clever.
But have to put the magnet in place each time you fall
. When learning it is tedious, no?
Hi @pablo_foil, great build! do you put the snap ring + golden washer back on the shaft (or leave them off like FD) and where do you cut the shaft? Thanks a ton!
I read a couple of comments saying they lost the bell, so I kept the ring for safety. Whatโs the goal of making it removable?
Thank you! I believe itโs to disassemble the motor easily to rinse it inside after each use.
